Engine Misfiring and Stalling, What to Do? [solved]
I was revving up to get on the highway the other day when the check engine light popped up. A mile later the car started misfiring pretty bad, and I limped it home. Since then, I have replaced the spark plugs and its only gotten worse. The car stalls at idle now and starts to miss really bad as soon as the motor gets warm. I took the oil fill cap off and looked down inside and the head seems to be vibrating with every miss. The engine doesn't sound right either, and it takes a lot of cranks to start. Any clue what could be going wrong? Obviously I can just get the shop to fix on monday but I'd rather do it myself if I can.
re: Engine Misfiring and Stalling, What to Do? [solved]
I hear ya, but the problem is bad enough I don't want to drive the car. I did a little testing and figured out its a random misfire, so not thinking plugs or coils.
reading the codes does not involve driving the car unless you disconnected the battery (ECU will lose the code)
if you don't have a reader, find a friend who have or buy one
Amazon have dongles that connects to OBDII port and connects to your phone, just need download an app.
update: limped car to autozone and got the code scanned there. its a code p340, cam position sensor. likely going to replace that tomorrow and see how it goes. I was shocked how much this little piece of the engine sensor apparatus debilitated my car. oh well. if anyone reads this thread looking to see if this is their problem in the future, the main thing I've noticed now is that the symptoms only really start when the engine warms up. The start, timing, and idle are all affected. all signs pointed to distributor cap when I was looking before but get 7s don't have one.
^ what he said.
I'd go to the dealership for conveniences sake. It will be more expensive (substantially more, I imagine), but it's what works.
Final Update
Got in there and did the job. It was harder than it seemed, i guess on our civics you need a spicy multi-angle socket to get to the timing belt cover bolt nearest the front, which i dont have, so i pulled off the entire front power steering pump and its mount that fastens it to the engine. after that things went pretty smooth. CEL is off and hasnt come back on so i'm considering this a win. thanks everyone for the advice, definitely getting a code reader asap.
Re: Engine Misfiring and Stalling, What to Do? [solved]
Good to know.
Yeah, it's a bit of a hassle to do. The 7th gens aren't amazing to work on relative to other Honda's. Of the 4 I've had, it was by far the worst.
GavinThornhill
General
Dec 14, 2020 05:09 PM
pro-cognizant
24
May 26, 2014 09:37 PM
cfahamilton
Jul 7, 2013 07:50 AM
