2001 civic in park with D flashing[solved]
Old May 12, 2024
crabbydad's Avatar
crabbydad is an unknown quantity at this point
just swapped transmission in my 2001 honda civic ex. Added5 qts of fluid then started car up to add rest and noticed that "D" is flashing and car is in park. I jacked it up and pulled shift cable off figuring i put it on wrong. When i manually shift the trans the Flashing D on the dash does not change? do I have a bad sensor? i used all the sensors that were on the transmission because they all seemed ok( no visible signs of damage)
any thoughts?
Old May 12, 2024
crabbydad's Avatar
re: 2001 civic in park with D flashing[solved]
the check engine light was on, pulled the code P1753-
Converter Clutch Solenoid Valve
swapped the solenoid with the one on the old transmission, the one on the new one was cracked, and this solved the problem
Old Dec 6, 2024
kurtbarlow's Avatar
kurtbarlow is an unknown quantity at this point
Re: 2001 civic in park with D flashing[solved]
I just dealt with the exact same issue except I forgot to plug in the TCC. 🙄😁
Iceprincess2017
Engine start problems
Feb 3, 2022 05:25 AM
trashman95
Electrical
Apr 24, 2021 09:56 PM
FearWRX
Feb 16, 2021 08:27 PM
Schurch1990
Oct 13, 2016 09:31 AM
pspmhofer
Electrical
Aug 19, 2013 04:23 PM
