Clutch is building no pressure
So the other day my 2001 civic sedan’s clutch pedal started getting stuck at the bottom and doesn’t come back up I already changed out the master cylinder which was part of the problem and I drained all the bad fluids out but I still don’t feel any pressure building up and it’s still getting stuck, could it be the clutch itself or is there anything else at play? Does anyone know what could be the issue?
Re: Clutch is building no pressure
Have someone look while you depress pedal to see if the arms at the transmission moves.
If not, keep bleeding
if yes, pressure plate could have collapsed
ychizh
Nov 12, 2009 07:54 AM
mntbiknfool
Aug 25, 2009 11:01 AM
mntbiknfool
Aug 23, 2009 03:38 AM
nj_represent
Sep 11, 2006 08:54 AM
