Issues after driving through high water
Old Aug 16, 2022
HeatherMollet's Avatar
HeatherMollet is an unknown quantity at this point
Soi drove thru so high water three weeks ago n 20 min later at a stopsign it stopped n wont go into gear since
Old Aug 16, 2022
Colin42's Avatar
Re: Helppp
Check for blown fuses
does it start?
Any check engine light?
Automatic or manual?
what year?
Old Aug 16, 2022
Re: Helppp
does it start?
what year?
dint know how to check fuses
Yes the engine light is on first it was coming up irregular gear ratio
Once tht was cleared now keeps throwing sumthing about a heater sensor issue
Old Aug 16, 2022
Re: Helppp
Its a 2005 honda civic automatic
Old Aug 16, 2022
Colin42's Avatar
Re: Helppp
Buy a $20 multimeter and watch a YouTube on how to check fuses. Could have water in the connectors as well.
Old Aug 17, 2022
BrotatoChip's Avatar
Super Moderator
Re: Issues after driving through high water
Changed the thread title to something more informative.
Old Aug 18, 2022
Harry Hemi's Avatar
Harry Hemi is an unknown quantity at this point
I suspect two things, your gear range selector which is really low on the case might have water in it (even though it should be sealed).
Or your tranny dipstick was loose and let water into the case. These cars over 100k miles always have loose dipsticks when people dont take care of them. If you went through water that was significantly higher than the dipstick hole, (around the middle of the wheel) pressure could force water in there.
If water got in there, it could screw up the hydraulic manifold. Because water is the nemesis to transmissions, that would be really bad. Thats a rebuild. Water turns manifold gaskets into glue.
Look at the transmission oil to see if its milky.
hondasdca
Air Conditioning
15
Jan 11, 2023 11:11 PM
Brodin Martin
Jul 6, 2020 12:59 PM
Shanvhere
Feb 27, 2019 01:56 PM
complexconcepts
May 17, 2011 09:20 AM
Sivion
Feb 13, 2003 07:19 PM
