2005 Honda Civic lx auto transmission not getting into gear
Old Jan 17, 2022
DuckyMoo's Avatar
DuckyMoo is an unknown quantity at this point
My automatic transmission is starting to have trouble shifting from 2nd to 3rd and even sometimes from 3rd to 4th. I had check my trans fluid to see if it was smelling burnt or had clutch dust and it had a little bit grit but I had checked it again but couldn’t find any grit. The fluid level was up to spec and was still a bright red. I had talked to my pops about what could be the problem and he said i might have to change the trans filter because of the grit that I felt but I’m not sure anymore. Any ideas and does this Honda come with a serviceable trans filter because I have seen some post about it being inside the transmission. Thanks in advance
Old Jan 17, 2022
Colin42's Avatar
Re: 2005 Honda Civic lx auto transmission not getting into gear
It's inside the case.
Try doing 3 drain and fills on the trans with the proper fluid to see if things improve
Ol Mans 91 LX
Apr 10, 2018 08:14 AM
06HondaCivicSi
15
Jan 20, 2015 10:39 AM
chadkassinger
Sep 12, 2013 08:54 PM
trixman
Nov 9, 2011 09:33 AM
pwhitmans
May 4, 2011 06:54 AM
