Will all manual axles interchange?
Old Feb 6, 2021
Phillip Lloyd's Avatar
Phillip Lloyd is an unknown quantity at this point
My car is 2HGES25705 I put a 1HGEM21964 IN.
I CHANGED THE MOTOR AND TRANSMISSION. The wiring harness work perfectly. No extra plugs. Im trying to use the axle that came with my car. But it seems to be to long. Does anyone know what's going on?
When I pulled the other motor I couldn't get the axle out so I cut it with a plasma cutter. That's why I can't use it.
Old Feb 6, 2021
Re: Will all manual axles interchange?
the only difference is that EM2 uses shorter gearing. Axles should go in the same. Isn't the CV joint coming close to separate? Depending on position you place, the ***** start to get out of their rails
You mention the wring harness, bu remember that the EM2 have VTEC, ES2 do not have ECU that controls the VTEC, so the engine will not work at its optimal, but should run.
Old Feb 8, 2021
Colin42's Avatar
Manual axles are different than auto axles, junkyard will be cheapest, unless you're in Ontario Canada, I have a set of manual axles I no longer need
Old Feb 8, 2021
oh, shoot, my bad
brians356
Mar 24, 2015 01:37 PM
samuelito210
23
Sep 10, 2014 09:48 AM
samuelito210
Apr 18, 2012 02:20 PM
joedc5
Jan 3, 2004 08:48 PM
integ108
Aug 24, 2003 05:15 AM
