2001 Civic 5 speed grinding in gear only under load.
Old Oct 20, 2020
Keith P's Avatar
Keith P is an unknown quantity at this point
Ok so I just picked up an 01 Civic LX with 245,000 as a beater. Overall car runs great but it's has a grinding noise coming from the tranny. I have read the articles on the difference between and TOB and an input shaft bearing but mine falls into neither diagnosis. Here is my best explanation.
If I am Sitting in neutral foot off of clutch there is no noise.
if I am moving under load there is a grinding sound in all gears.
If I put the car in neutral as I am going any speed all grinding noise goes away.
I pulled a little bit of the tranny fluid and it is black so I am sure it could use changed but I am curious as of the source of the grinding noise since it doesn't fit either of the common descriptions. Thanks for the help!
Old Oct 21, 2020
FRSam's Avatar
Click Here
Re: 2001 Civic 5 speed grinding in gear only under load.
Just to clarify, it doesn't grind going into gear, but only grinds when it's in gear? It almost sounds like the clutch isn't fully engaging.
Old Oct 21, 2020
BrotatoChip's Avatar
Super Moderator
If you let off the throttle while driving but still in gear does it still make the noise? Bad CV?
Kevin Bice
Mar 3, 2017 08:27 PM
Grassflatsfishe
Dec 18, 2011 04:58 PM
Ben Kenobi
Jul 18, 2011 11:30 AM
Harky000
May 18, 2010 07:39 PM
hyperactive
Sep 20, 2003 09:37 AM
