Weird Noise When Shifting
Old Jun 22, 2011
Ben Kenobi's Avatar
Ben Kenobi is an unknown quantity at this point
Post Weird Noise When Shifting
2000 Civic Ex with 108k that i just bought is making a "grinding" noise when shifting. It normally happens when shifting from 2nd to 3rd gear then won't go away, sometime it doesn't even happen at all. Some friends said it might be the throwout bearing. Also If i have the clutch pressed all the way to the floor, while its making the noise' the "grinding stops.
The grinding reminds me of the way a diesel engine sound.
Comments welcome
Old Jun 25, 2011
TRIZ's Avatar
Re: Weird Noise When Shifting
Yikes, that sucks. In for an answer.
Old Jun 25, 2011
newyota's Avatar
newyota is an unknown quantity at this point
Throw out bearing will stop making noise usually when you press in the clutch because it is not under load anymore.My 2000 EX has what I'm pretty sure is a throw out bearing.
Old Jun 25, 2011
Muirsy's Avatar
Muirsy is a jewel in the roughMuirsy is a jewel in the roughMuirsy is a jewel in the roughMuirsy is a jewel in the rough
3rd gear synchro worn out maybe?
Old Jul 18, 2011
Ben Kenobi's Avatar
Changed the Transmission fluid and found out the previous owner was using automatic tranny fluid. The sound died abit down sound more like a growl than a grind now.
Jul 12, 2015 11:54 AM
jody501
Jul 10, 2015 11:01 AM
Steinar.D
Transmission
Jul 10, 2015 01:38 AM
1khilari
Jul 9, 2015 08:12 PM
fvckbg
Jul 7, 2015 07:08 PM
