Car runs but won't shift into gears!
Old Sep 10, 2020
CivicNewbie10's Avatar
CivicNewbie10 is an unknown quantity at this point
Angry Car runs but won't shift into gears!
I got stuck on a flooded road and my civic stalled. I was able to get it out and running again, drove home and seemed fine. The next morning I went to start and there was one bang when it tried to turn over, i waited a bit and tried again. It started right up and left it running for a long time until the engine was warm and the rpm's dropped from 1,200 to 800 (where it usually ideal's) I then put it into first and move the car where i left it until my brother was able to come over to check it out with me. started it up was really trying to stall but kept it running and let it warm up just as before. Went to test drive it and now it wont go into any gear. It grinds horribly trying to put it into reverse and gears 1-5 won't go in and the rmp's rise when I try. Any thoughts???
2003 Honda Civic Coupe dx Manual 1.7L
Old Sep 10, 2020
BrotatoChip's Avatar
Super Moderator
Re: Car runs but won't shift into gears!
Have you verified the clutch is releasing when the pedal is pushed?
Old Sep 11, 2020
I'd expect the clutch disc is now stuck to either the flywheel or the pressure plate, due to rust.
I would push the clutch pedal down.
Put shifter in 1st or reverse whichever way is clear for the car to move.
Push clutch pedal down.
Start the engine.
The starter alone will move the car until the engine starts up. As soon as the engine starts, you'll be driving down the road. So you better be ready to control it. If you can't control it, **** could get really exciting.
I'd hold the clutch pedal down while briefly and repeatedly stabbing the gas pedal to the floor until the clutch is unstuck.
The clutch disc may break free when you try to crank it with the pedal down. It may stay stuck until it's jarred free.
Old Sep 13, 2020
I started it while it was in first gear with the clutch pedal pressed all the way in and the car jumped and stalled. It seems like its not disengaging. I can however shift through all the gears while the engine is off but, when the car is running it wont go into any gears. Id assume this must be an electrical issue??
Old Sep 13, 2020
Colin42's Avatar
How is the gear stick related to anything electrical?
Old Sep 14, 2020
Super Moderator
You don't need the clutch to shift through gears while the engine is off. No this isn't an electrical issue, it's a completely mechanical system. You verified the clutch isn't disengaging which is why the car lurched forward when trying to start, now figure out why. Pull the rubber boot off the slave cylinder and have a someone push the clutch pedal, is the slave cylinder moving? If the slave is moving then it's looking like Ezone is correct.
Ravensfh
Mar 22, 2015 05:33 AM
Northern Pyro
Aug 5, 2013 07:02 PM
ctown
Dec 21, 2008 12:42 PM
alienmonkey
Feb 6, 2002 10:32 AM
