Won't shift into 5th and reverse, now what
Old Dec 12, 2008
ctown's Avatar
ctown is an unknown quantity at this point
Hi, gotta a problem, car won't shift into 5th or reverse.
Where do I check first, has something come lose on the shift linkage, or do I have a problem with the cable in the shifter.
Any idea where to start to figure this out would be appreciated, I have a 2004 civic sedan.
ctown
Old Dec 13, 2008
ctown's Avatar
Re: Won't shift into 5th and reverse, now what
I got a feeling this is not a common problem, it came on real sudden, jumped into the car and I can't shift into reverse.
I am driving down the road (after I push my car out of a parking spot in a howling blizzard), I shift into fifth it won't stay, it simply pops out, bizarre.
If know idea's surface here it looks like I off to the local honda stealer.
If any thoughts on this thanks in advance.
Old Dec 14, 2008
pon55's Avatar
check your cables.
Old Dec 15, 2008
LemmieHill's Avatar
LemmieHill is a jewel in the roughLemmieHill is a jewel in the roughLemmieHill is a jewel in the rough
If you are somewhere that you need reverse, try shifting into reverse before you start the car. You can also hold it in position and slowly let the clutch out slowly while applying light pressure to the shifter and if its something with the syncros then, when the gear teeth line up with the sleeve teeth due to the motor spinning the tranny it will go into gear. Usually 5th and the reverse idler gear share the same sleeve which is why you lost both. Try getting the car into gear and see if it transmits power when you release the clutch.
Old Dec 15, 2008
ctown's Avatar
Thanks for the info, I am hopping cables and not gear box.
Once again thanks for the info.
Old Dec 19, 2008
ctown's Avatar
Yup, it true my transmissionis toast, I am told by the dealer its the bearings. He would not even give me the price of a rebuild on this trany (scary cost).
They told me to put in a used transmission, which is the way I will go.
Crap, it's a 04 with 65,00 km's on it, I am guessing that the car has had a harder life than I knew.
No hidden warranty on this.
Don.
Old Dec 19, 2008
pon55's Avatar
Take it to a private shop for a "second estimate".
Old Dec 20, 2008
ctown's Avatar
sounds like a good plane
Old Dec 21, 2008
LemmieHill's Avatar
Um, yea id most def get a second opinion if they are telling you that your 5th/rev is due to a bearing. If its a bearing, 9 times out of 10 you will hear that in all gears.
Old Dec 21, 2008
ctown's Avatar
The funny thing is I can't hear any bearing wine, trany is quite.
There was no warning, suddenly I am locked out of reverse and it won't stay in 5th, crazy.
Civic15
18
Sep 19, 2017 07:48 PM
f575gtc
Transmission
Jul 13, 2015 09:16 PM
Jul 12, 2015 11:54 AM
Steinar.D
Transmission
Jul 10, 2015 01:38 AM
fvckbg
Jul 7, 2015 07:08 PM
