‘05 Civic manual transmission fluid
Old Jun 6, 2020
pitnut's Avatar
pitnut is an unknown quantity at this point
I’m wanting to change my transmission fluid, Honda recommends their mtf fluid which I have one quart of. I don’t have access to anymore at the moment besides eBay and was looking for an alternative. What would you guys recommend and what weight is the fluid? I most likely won’t mix them though
Old Jun 6, 2020
Wankenstein's Avatar
Re: ‘05 Civic manual transmission fluid
Looks to take 1.9 qts to fill manual transmission. Use Honda brand mtf only. Other brand mtf fluids could potentially damage the gear synchros by harming specific metals the synchros are made from.
Not worth taking the risk...wait to do the change after you receive the Honda mtf.
During the mtf change make sure to remove the fill bolt first before removing the drain bolt. You don't want to be in a position in-which the oil is drained and you're unable to remove the fill bolt.
Old Jun 6, 2020
Colin42's Avatar
Only use MTF
Old Jun 8, 2020
FRSam's Avatar
Click Here
Honda dealership doesn’t have any? That’s where I get mine.
brags
17
Apr 8, 2018 03:53 PM
user 987458
Sep 1, 2013 09:52 PM
usvpn
May 27, 2012 07:28 PM
astr033
May 28, 2009 05:34 PM
infinite
Mar 8, 2007 11:38 PM
