Manual transmission is leaking fluid somewhere.
Old Sep 2, 2019
thesupersoap33's Avatar
thesupersoap33 is an unknown quantity at this point
I changed the axles a little over a year ago and I dont think it was leaking before that. I was trying to fix a popping noise that ended up being the lower control arms. Yesterday, I replaced the drivers side axle seal, thinking that would fix the problem since there was tranny fluid dripping down onto the cars subframe from there. Drove it about 50 miles and checked and it's still leaking. It was such a pain in the *** to change the seal and still have it leaking on me. Any suggestions?
Old Sep 2, 2019
Colin42's Avatar
Re: Manual transmission is leaking fluid somewhere.
Did you use OEM seals?
Old Sep 2, 2019
Slumpertcivic's Avatar
Here I was thinking the likely aftermarket axle possibly was undersized, corroded, or the splines were not de-edged and cutting the seal on installation.
Old Sep 3, 2019
BrotatoChip's Avatar
Super Moderator
The axle seal can also be installed too far into the transmission causing a leak.
wagojoe
Transmission DIY
Apr 1, 2018 07:25 AM
wagojoe
Mar 30, 2018 09:13 PM
relative4
Jan 18, 2018 07:10 PM
thisguy
Aug 9, 2011 02:49 PM
laack
Oct 24, 2009 04:03 PM
