Can’t Shift Into Gear
Old Jul 10, 2019
Bryan Futral's Avatar
Bryan Futral is an unknown quantity at this point
I have a 2001 Honda Civic with a 5 speed transmission. I have only owned the car for the past 2,000 miles and have no idea what has been done to the car. The other day I was driving down the road and went to down shift to turn onto another road and didn’t have a clutch. The pedal was very spongy and I could not shift into gear without forcing it in. I checked the slave cylinder on the car and the boot was tore up so I figured that was my problem. I’ve bleed the clutch several times now and can get some pressure back on the clutch pedal but it still doesn’t exactly feel right. It’s got pressure on it but sticks alittle then comes back up. Could it be something in the actual transmission such as the pressure plate or is there any trick to bleeding the line that I just don’t know about?
Old Jul 11, 2019
Colin42's Avatar
Re: Can’t Shift Into Gear
it's really hard to bleed the clutch, pick up a vacuum bleeder, or get some one to help you. did you put in a new slave?
Old Jul 12, 2019
Slumpertcivic's Avatar
I would fully expect the pressure plate / throw out bearing / friction disc / flywheel to all be suspect of being worn out but if your clutch fluid level did not drop out, I would suspect a failed clutch master cylinder as once a internal seal fails it instantly cannot build pressure effectively anymore.
dsmoore
16
Mar 18, 2016 08:33 AM
Mkalby
Nov 30, 2012 03:31 PM
conquesimo
May 19, 2011 08:27 PM
Gold Ghost
17
Aug 8, 2010 06:04 PM
2K1Civic17"Gabe
Jun 30, 2005 04:12 PM
