Clutch adjustment
Old May 16, 2019
OKCEM2's Avatar
OKCEM2 is an unknown quantity at this point
Clutch adjustment
In the process of getting my 03 back on the road. Been out of commission for 9 years. Recently replaced input shaft bearings, seals, clutch, pressure plate, flywheel, all clutch bearings and rear main seal among other small things. My issue is the clutch engagement is extremely tight. Difficult to change gears and engagement is damn near to the floor. Bled the system with some improvement but still difficult to shift. I have. A new master and Slavs on the way in hopes this remedies the issue. My question is, is there any adjustment within the system other than the clutch pedal height? Thx in advance
Old May 17, 2019
Slumpertcivic's Avatar
Re: Clutch adjustment
Sounds like you have air in the system.
Practically impossible to properly bleed air out of the clutch system without 2 people or a vacuum bleeder.
When I changed my clutch, I was pumping chocolate looking clutch fluid out for ages till it got clear.
Old May 17, 2019
OKCEM2's Avatar
Thx for the response. However I’m certain there’s no air in the system. I did have a second person when bleeding the system. There is some minimal play in the slave plunger which makes me think it could be worn. The car has less than 90k miles. I’m the original owner so I know what the car has been through. I did have a HD ACT clutch prior to the rebuild so I’m not sure if that pressure plate caused damage to the fork or slave. Wouldn’t think so... everything looked normal when going back together
Old May 17, 2019
It’s hydraulic and by design automatically adjusts itself.
A bent fork, would change the angles of the system so you would end up with less “throw” .
What clutch kit did you use?
Old May 17, 2019
OKCEM2's Avatar
Went back to a stock clutch
firecatf7333
Dec 24, 2017 05:41 PM
em2maxamillian
Dec 4, 2012 12:10 AM
Mkalby
Nov 30, 2012 03:31 PM
chopper202
Oct 6, 2009 03:30 PM
Snakes
Bolt-on Engine Performance
Mar 2, 2003 11:52 AM
