Transmission slipping when hot
Old May 21, 2019
Jack2274's Avatar
Jack2274 is an unknown quantity at this point
Have 2005 Honda Civic lx.when the car heats up the transmission starts to slip and the car won't pull.let the car cool off and it will drive untill car gets to running temp.any ideas out there what's wrong or have similar problem they fixed
Old May 22, 2019
Slumpertcivic's Avatar
Re: Transmission slipping when hot
If your lucky it’s a solenoid that’s failing when hot or your simply low on fluid and it begins to “froth” with air bubbles.
Either way there should be fault codes loaded and your MIL light should be on.
Have you had the car scanned for codes yet?
Old May 22, 2019
Mikeyyy's Avatar
Mikeyyy is an unknown quantity at this point
The easiest and first thing to do is check your transmission fluid.
Do you know if it has ever been change and if so when?
MsCandy
Jun 20, 2017 12:17 PM
Mac_the_ripper
Transmission
Dec 5, 2014 11:34 PM
nojro
Jul 20, 2013 10:38 AM
Gummiesaver
Feb 28, 2011 06:52 PM
jfman
Sep 27, 2007 09:10 AM
