Transmission range switch
Old Apr 17, 2019
Sellacell's Avatar
Sellacell is an unknown quantity at this point
My 2001 ex was throwing an engine code for transmission range switch, so I replaced it (literally just unplugged old one and plugged new one in). Now when I start the car it shows it’s in neutral even though it’s in park, and won’t let me shift into any of the other gears. Any idea what might be going on?
Old Apr 17, 2019
Re: Transmission range switch
Wrong switch?
Wiring problem instead of switch problem?
Old Apr 17, 2019
Sellacell's Avatar
Apparently you have to adjust it so that it’s in park when you put it on. I adjusted it, but it kept slipping and messing up after you shift through the gears a few times. I got it in the right position and tried to tighten it enough that it wouldn’t budge when the gears shift, but then the bolt broke off in it. I’m my way to get an easy out and a new bolt right now.
Lopezsoul
Oct 29, 2015 08:30 PM
Civic_RedLine
May 18, 2005 04:54 PM
Civic_RedLine
Dec 30, 2004 12:04 AM
4drcivic112
Apr 20, 2004 10:12 AM
biohazard
16
Aug 26, 2003 07:27 PM
