Where can I find a bushing for the shifter? 2002 CIVIC
Hi My shifter was getting noticeable noisier, turns out that the bushing that connects the rod to the shifter cable disintegrated. My car is a 2002 Honda Civic (4dr ES4) where can I find a replacement ? I'm not a native english speaker so which terms shall I search to find this part? I believe Honda doesn't sell this part, the only way to get it through honda is buying the whole cable assembly.
Image of the bushing i'm referring to https://imgur.com/a/HiVS23L
Thanks for your help
Re: Where can I find a bushing for the shifter? 2002 CIVIC
Will this fix my issue? https://www.ebay.com/itm/Mr-Gasket-M...s/262623828614
ask the seller?
i am assuming you have an auto trans? manual will be different.
have you looked at the online retailers?
this is one.
https://www.hondapartscheap.com/auto...t-lever-1-scat
if you want some others, we listed some here:
https://www.civicforums.com/forums/1...retailers.html
this is one.
If you cant find them for the civic, the rsx ones fit to. You can also buy aluminum upgraded bushings online; these feel nicer with a crisp shift, but you will feel more vibration.
ask the seller?
this is one.
this is one.
Regards
Solved using the O-Ring method https://forums.clubrsx.com/showthread.php?t=1099794
sl33pyriceboi
Jun 9, 2007 03:56 PM
