05 EX leak on top of transmission
Old Dec 12, 2018
FijiEM2's Avatar
FijiEM2 is an unknown quantity at this point
One or some of you here may have dealt with this once before. I have a 2005 civic EX. Car is automatic. Ive got t gis leak that's been happening somewhere under the left side of the head and the top of the transmission. I have replaced the vtec solenoid gasket, and replaced the triple o-ring on the shift sensor right at the top front of the transmission.
Added some dye to the engine oil but the leak had NO dye in it. We removed the engine oil cap and looked inside and the oil reacted with the UV light. So it tells us that the leaks has to be transmission fluid related. We replaced the o-rings on the solenoid up front and cleaned everything with brakekleen and purple power. No the leak is back and it looks exactly as it did before.
I'm at witts end trying to figure this out. Any help is appreciated.
Old Dec 12, 2018
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Re: 05 EX leak on top of transmission
Check for a leaking ATF dipstick. I know mine is loose and really should replace it but does not leak. Check out this thread: https://www.civicforums.com/forums/1...sion-pics.html
Old Dec 12, 2018
FijiEM2's Avatar
Dipstick area completely dry and it's in an area that isn't currently wet from the leak.
Old Dec 12, 2018
NDNV's Avatar
Found a Youtube vid on the subject too.
A common engine oil leak is the Camshaft End Plug right next to the EGR valve on the side of the cylinder head. But you are sure that the leak is ATF.
Old Dec 12, 2018
NDNV's Avatar
If ATF level is too high or overheated, there may be breather hose that could spew ATF.
Not sure if the transmission mounts are hydraulic filled or not but is that a possibility?
Old Dec 12, 2018
FijiEM2's Avatar
Was about half quart low but it's been topped off to proper level a few weeks ago. MOUNTS are rubber as far as I know.
Old Dec 12, 2018
Slumpertcivic's Avatar
The front passenger transmission mount has fluid in it from the factory.
I had a seized bolt and ended up tearing the mount and nasty stuff spewed all over me.
Old Dec 13, 2018
FijiEM2's Avatar
This seems to be a common issue but other threads don't seem to have a definitive or concrete solution.
Old Dec 13, 2018
Colin42's Avatar
could clean everything off, take it for a drive and then check to see if you can tell where it's coming from
Old Jan 11, 2019
FijiEM2's Avatar
After a recent visit to honda they said the VTEC (Spool) Solenoid is defective. While we did change the gasket with the screen there is an internal o-ring that appears to have failed. Will reply back once I change the valve out and clean up the mess.
Old Jan 28, 2019
FijiEM2's Avatar
Bad O-ring in the top portion of the VTEC solenoid caused the leak it was OLD and stiff as a board with a few cracks. Finally gave up at 280K miles.
excel9976
May 14, 2018 09:49 PM
0396
Feb 19, 2017 01:17 PM
D16
Feb 18, 2017 10:27 AM
iliketogetdirty
Apr 11, 2016 11:08 PM
nuke777
Feb 5, 2015 03:45 PM
