Changing synchro in 03 ep3
Old Apr 22, 2018
Docwatson87's Avatar
Docwatson87 is an unknown quantity at this point
How hard is it to pull and change out synchro on 03 ep3 transmission? 3rd gear grinds unless I gingerly move the shifter. Any help is appreciated thanks in advance.
Old Apr 22, 2018
RobertD's Avatar
RobertD is a jewel in the roughRobertD is a jewel in the roughRobertD is a jewel in the rough
Re: Changing synchro in 03 ep3
manual trans are fairly simple to rebuild, provided you have good instructions and you are very detail oriented.
http://www.ephatch.com/forum/showthr...ission-Rebuild
i would recommend getting another trans and rebuilding yours as a side project. this reduces stress on you, eliminates the need to rush, and keeps the car on the road while you do it.
i rebuild my mustang transmissions as i wear them out. i've never changed just a synchro. to fix a grinding gear i replace the 3 synchro parts as well as the gear, the slider, the shift fork pads, also any spiro-locks, snap rings, etc.. so usually it's a rebuild kit, plus a gear, plus a slider. the only special tool i needed to buy was a good snap ring pliers and a $40 bearing splitter. here is a gallery of me assembling a tremek T5. https://goo.gl/photos/LuPRB69Pug5N7zuG6 i think it's kinda neat to flip through. every time i added a part, i added a picture. i find this is a fun and rewarding process, and afterwards- every time you shift, you'll know exactly what is occurring.
i purchased a rebuild DVD. i follow along, pausing it and rewatching the steps as i go. if they have one for your trans, i think you'll find it WAY more useful than anything you can read
Old Apr 22, 2018
mac25's Avatar
Dr Krieger of Modification
If you have the skill level, or time to mess up and learn form a mistake, then it is easy.
Take lots of pictures before you take the sacks apart.
Here's a DIY
Old Apr 22, 2018
Thank you I really appreciate it
minorsecond
Feb 11, 2010 09:35 PM
theclassiczero1
Aug 2, 2006 07:13 PM
whitedawg
Oct 15, 2005 02:27 PM
JCiv03
North Cali
27
Sep 11, 2005 12:08 AM
civicSi
Apr 2, 2002 09:32 PM
