trainny issues help please
Old Mar 1, 2016
X3R0CO07's Avatar
X3R0CO07 is an unknown quantity at this point
hi guys
im going to start saying that i needed a new clutch in my car so i bought a clutch kit. i put the new clutch in put back the transmission couple days after the car was making a weird noise when it was in gear. so that day i was backing out of a parking space when i stop and put it in 1st gear i hear a boom noise not too loud after that the car doesn't take any gear at all car has 180k on it. any suggestions ideas of whatever you think it might be please let me know and thank you in advanced.
Old Mar 1, 2016
Re: trainny issues help please
What steps have you taken to inspect and diagnose for this new problem?
Is the trans lube full?
Did you not refill the trans with the proper lubricant after you did the clutch job?
Did it leak out?
Did an axle pop out?
Did an axle break?
Did the shifter all of a sudden feel super loose?
Old Mar 2, 2016
X3R0CO07's Avatar
tranny has lube the same lube it was there before.
i didn't leak out.
today i look at the axles and they are fine and in place.
shifter feels the same.
i notice today that i can put the car in gear a had a friend start the car while i watch the axles a the didn't move now i can tell the tranny is putting output because if a put in gear i can hear it grading it become Lauder with a higher gear tomorrow im going to putting in a lift and check underneath the car and on the weekend im planing to remove the tranny if i cant see whats wrong.
Old Mar 2, 2016
What sort of clutch kit?
Well known brand name?
Ultra cheapo?
Did you test fit the disc on the splines of the input shaft before install?
Did the new disc fail somehow?
Old Mar 5, 2016
X3R0CO07's Avatar
so i put the car in the lift today turn out the driver side axle pop out im going to see if it goes back in if it doesn't im going to replace it any other suggestions?
Old Mar 5, 2016
If the axle does not pop in and latch securely, there's a problem.
If it doesn't latch, pull it all the way out and see if it sheared the end off at the snap ring groove.
Old Mar 5, 2016
X3R0CO07's Avatar
It did shears a bit of the end should I replace it anyway?
Old Mar 5, 2016
Yeah if they will exchange it, I'd replace it.
Hope the shavings from the splines on the end don't cause other issues in the trans later on.
Question would have to be, was it not fully seated when you assembled it, or was the snap ring weak and couldn't keep it from popping out on its own?
Hani4g
Oct 31, 2015 02:09 PM
Othelius
Oct 23, 2015 07:25 PM
ThatGuy913
Sep 28, 2015 05:35 PM
PimpBot5000
Nov 26, 2001 07:15 PM
aZnVoYCe
Bolt-on Engine Performance
Nov 4, 2001 10:18 AM
