Transmission? Clutch? Axle?
Old Oct 23, 2015
Othelius's Avatar
Othelius is an unknown quantity at this point
Hi guys, i have a weird one here for you. I was driving my 97 civic yesterday, and as soon as i released the clutch going in to second gear i heard a pop, and now the car won't go in any gear. The clutch feels the same, I can shift into gears, but when I let out on the clutch the car doesn't even attempt to move. Any insight is appreciated.
Old Oct 23, 2015
Poopies's Avatar
Super Moderator
Re: Transmission? Clutch? Axle?
Have you changed the clutch and transmission fluid lately?
Old Oct 23, 2015
Othelius's Avatar
No, the only thing I have done is add hydraulic fluid to the clutch reservoir a few months ago, it still has plenty in it.
Old Oct 23, 2015
Poopies's Avatar
Super Moderator
Have you looked at the shifter cables? Maybe one snapped or popped out...
Old Oct 23, 2015
Othelius's Avatar
I hear all of the linkage moving around when I shift, but probably should dig a little deeper, I will let you know what i find
Old Oct 23, 2015
Poopies's Avatar
Super Moderator
Sounds good. Take pictures of anything that looks... off.
Old Oct 23, 2015
Run the engine and put trans in a gear, act like you are trying to go somewhere.......Does the speedometer needle register any speed?
If it registers speed, then your problem is CV joint or axle related.
Broke a CV joint or broke an axle, or an inner joint popped out of the trans.
Old Oct 23, 2015
Othelius's Avatar
I will check it out, i dont think it did, but didnt pay much attention to the dash
PinkCupcakes
Electronics
Jul 18, 2019 12:50 PM
usajags84
May 30, 2015 06:49 PM
RyanCoult
May 29, 2015 09:50 PM
dinsum
May 28, 2015 09:30 PM
Markias
Detailing
Nov 4, 2001 05:15 PM
