02 civic clutch still squeaks(already packed the push rod with grease, still squeaks)
Old Jun 16, 2013
hondaguy2582's Avatar
hondaguy2582 is an unknown quantity at this point
Figured it out!
Thanks!!!
Old Jun 16, 2013
Re: 02 civic clutch still squeaks(already packed the push rod with grease, still sque
Maybe it's not the pushrod.
Clicky: http://www.skidmore.edu/~pdwyer/e/files/tsb/a02-002.pdf
How about....can you operate the clutch fork arm with a large screwdriver and see if the noise is still there without the slave in the picture?
HTH
Old Nov 13, 2023
SprMnRcr1728's Avatar
SprMnRcr1728 is an unknown quantity at this point
I know this post is 10 years old but hopefully someone sees that knows how to fix this issue. How did you fix yours hondaguy? I put some of the best bearing grease money can buy on the csc rod (polished and put on both ends)and still have the damn squeaking from clutch fork. If I even lightly touch the clutch fork it goes away. Wondering if when adjusting my clutch pedal it's to loose. Meaning loose rod not pushing on the clutch fork enough?
Old Nov 14, 2023
BrotatoChip's Avatar
Super Moderator
There are two concave parts on the clutch fork, did you grease them both? One where the clutch piston pushes, and one where the clutch fork pivots in the middle.
surge6644
Jun 26, 2014 04:39 AM
number4t1
May 21, 2009 02:30 PM
bakablo
Oct 4, 2004 09:58 PM
KalliGarri
Apr 5, 2004 10:35 PM
