I've got transmission issues!
Old Jun 18, 2011
GreenFamily's Avatar
GreenFamily is an unknown quantity at this point
Question I've got transmission issues!
Alright this is an odd one, I've been searching around, asking questions and nobody seems to have a clue. There are two issues here that are concerning me about the transmission in my 2002 DX.
1. At launch (not every time and only when pushing it hard) first gear makes a loud whine that will continue into second as-long-as I stay into the throttle. This 'whine' sounds similar to reverse but its louder are far more intense. It's done this for a long time, again only when under heavy load, only about 20-30% of the time and only when the clutch is engaged(foot off the pedal).
FYI I've replaced the clutch, throw out, pilot bearings, and the engine(spun bearing) since this noise started.
2. Now for the one that's ticking me off. Second, third and forth gear pop 'halfway' out under light driving conditions. They don't seem to ever pop out under load more just while maintaining cruising speeds. Second doesn't do it too often but when it does its usually during a left turn at 5-10MPH during light deceleration. Third and forth gear seem to do it at about the same time. When cruising at between 30-40MPH in third or forth with little to no throttle it will pop out of gear. When it pops out of gear its only coming out halfway so you will hear a very slight gear grinding. I can disengage the clutch, put it right back into gear and it will do it three to four more times in a row then be fine again for 10-15 miles. I have found that when it comes out of gear I can(without touching the clutch) give the engine a slight rev and it will drop right back into gear as if i was compression shifting. It only started doing this after replacing the engine, clutch, throw out and pilot.
To say the least, I'm miffed...
BTW, running Redline MTL in the transmission, started using it because of the gear popping out.
A little back story:
The car is almost completely stock, the motor was replaced because it spun a bearing during my commute home one day. I replaced the clutch and bearing at the same time as the engine in hopes that it would address the whine, there was still a lot of material left on the old clutch. When I bought the car used I had known that I would be replacing the motor at one point or another because the previous owner hadn't changed the oil in the three years she had owned it and the pan only had about a half a quart of sludgy oil. I picked the car up for a really good deal to say the least and had an extra D17A1 sitting in the garage. Incredible motor by the way, I put 30,000 miles on it before it spun the bearing and that's a long time for an engine that's been run out of oil.
I love this car, it's been the most efficient commuter I've ever owned.
Old Jun 18, 2011
MelJ's Avatar
Trance Addict
Re: I've got transmission issues!
It's possible the shift fork could be bent. The hop out could also be caused by a worn synchronizer. Could explain the noise as well.
Old Jun 18, 2011
The noise is loud and intense but hard to explain. If it stops raining today I'll try to set up the camera and catch a video. It's actually hard to get it to do it on demand.
It would best be compared to the noise you would hear if you punched it in reverse but amplified the audio.
Old Jun 18, 2011
lazlong's Avatar
Welcome to my world, I've driven with that sound since '07. My buddy who runs the tranny shop told me it's the throwout bearing but, if you've replaced yours then it may not be the throwout.
Like stated above, popping out of gear is the synchronizers or a bent fork.
jackshepardjr
May 24, 2015 09:53 PM
Midnapore
May 18, 2015 11:37 AM
cruisers10
May 12, 2015 10:46 PM
Jessica Leung
May 5, 2015 05:12 PM
markp94
Apr 30, 2015 09:19 PM
