Single "click" noise when shifting gears
Old Jun 21, 2011
anibis's Avatar
anibis will become famous soon enoughanibis will become famous soon enough
2005 Civic, MT, 116k
For the past couple months I've been having a single "click" as I'm releasing the clutch and start accelerating. Basically when the drivetrain goes from no torque put through it to abruptly having some, if that makes any sense. It also will click if I'm driving in a low gear, bring the revs up to 3k or so, then take my foot off the gas, when the car starts to decel it'll click.
If I'm real easy it only clicks *some* of the time.
It's never multiple clicks, just one. Seems to be coming from the right side.
It's a lot like the classic CV joint "click" but it doesn't do it when I turn. CV boots are not torn and don't appear to be leaking.
I read it could be the inner CV joint? I've always had the outer joint go out first, always after a torn boot.
Any ideas?
Old Jun 21, 2011
mvanbv00's Avatar
mvanbv00 is an unknown quantity at this point
Re: Single "click" noise when shifting gears
I have the same click noise. I have an auto transmission though. I can really hear it well when I am next to a curb or another car (the sound reflects back to me) and let off the gas.
I was just about to post the same question. I have been wondering this also.
Old Jun 22, 2011
johndeerebones's Avatar
johndeerebones is a jewel in the roughjohndeerebones is a jewel in the roughjohndeerebones is a jewel in the rough
sounds like a motor/transmission mount
Easy enough for a auto guy. Put it in gear and brake tourqe it with a bystander trying to locate it.
Manual trans guy, put the park brake on and with a combo of clutch and gas see if you can replicate it.
Old Jun 22, 2011
lazlong's Avatar
^^ Dam, you beat me to it by 3 minutes!
Old Jun 23, 2011
anibis's Avatar
It looks like the front and transmission mounts have a crack all the way through the rubber, the left side mount looks fine and no oil leaking, I can't see the rear mount.
I read that I should use factory mounts because the aftermarket versions cause more vibrations, is this correct?
What about those inserts for the front mount?
Old Jun 23, 2011
Originally Posted by anibis
It looks like the front and transmission mounts have a crack all the way through the rubber, the right side mount looks fine and no oil leaking, I can't see the rear mount.
Noticed mine was busted when I pulled the transmission. I replaced it with one from Napa. Quality seemed fine and it doesn't have any vibrations and NO clunk....
Old Jun 23, 2011
lazlong's Avatar
Polyurethane mounts are harder and cause more vibrations.
Poly replaces the rubber in the mount.
97-DX-Lover
Jun 14, 2015 06:07 PM
Chris71087
Jun 9, 2015 11:59 PM
Srudet
Jun 7, 2015 09:34 AM
cruisers10
May 12, 2015 10:46 PM
EC3
Apr 22, 2015 07:55 PM
