Is my clutch gone?
Old Jul 13, 2009
grey2k11's Avatar
grey2k11 is an unknown quantity at this point
Exclamation Is my clutch gone?
Hey guys, new to posting but always use this site for info.
While I driving home today I tried to switch to 3rd and it wouldnt go in gear. I tried to switch to 2nd and that wouldnt go in gear either. I pulled in a parking lot and got my friend to help me push my car home.
This is whats happening.
I can still turn the car on in neutral. If i try to get into a gear while the car is on, it won't go in. If the car is off, the gears slide in flawlessly. I started the car in gear with the clutch engaged and I hear a VERY loud winding noise. It seems to be coming from the clutch.
My car is a 02 civic with 101k miles and has a stock clutch. Is it most likely time for replacement? Are these the symptoms? If so where and what clutch should i be looking for? What clutches better than others? Pricing matters also.
Is installing this a problem? Moderate experience with both parties who would be working on it. 1 of which has already put a clutch in on a same year and model car with help from someone else.
Old Jul 13, 2009
rednwhite04's Avatar
rednwhite04 will become famous soon enough
Re: Is my clutch gone?
did you check your fluid level under the hood? Your clutch runs off hydraulic pressure, if the fluid is low you may have these symptoms. Otherwise, with the car off and e-brake set put it in 4th gear. Start the car and slowly let the clutch out, the car should die almost immediately if your clutch is good.
Old Jul 13, 2009
badhabits's Avatar
badhabits is an unknown quantity at this point
Be careful though with reds suggestion. I had a clutch go out on my old prelude, with the same symptoms as yours, and starting it in gear with or without the clutch pedal to the ground would result in the car leaping forward and taking off on its own. I knew it was junk time for that car, so i drove it like that forcing the stick between gears in its "sweet spot", and yanking the stick to neutral before stopping. Then turning the car off, starting it in first gear to take off, and repeating at every stop.
Old Jul 14, 2009
grey2k11's Avatar
which fluid would i be looking to check? My oil? I am do for an oil change but i wasnt gonna do one till after the swap of my clutch. but if thats the problem then ill do that first.
Excuse me if my post is completely no where near the question i should be asking. Noob here.
FLuid? Which fluid?
Old Jul 14, 2009
grey2k11's Avatar
I started my car in 4th. E brake pulled and let go of clutch. Car Died.
The sound coming from my car while i did that is the loudest noise ive ever heard from my car and it seems to be coming from the clutch. The fluid also seems to be filled to the top. Will flushing(if possible) the fluid out and replacing it possibly fix my problem?
Old Jul 14, 2009
Protan988's Avatar
Protan988 is an unknown quantity at this point
No it is not the engine oil lol. It is your clutch fluid which is in the top right corner of your hood. Right beside your brake fluid, near the master cylinder. I hope that helps.
Old Jul 14, 2009
BlueEM2's Avatar
Whachya lookin at?
Strange, those symptoms arent really the symptons of a "worn" clutch. I'd check your fliud first and then check the master and slave clutch cylinders and make sure they are okay. If your clutch was worn then you should be able to physically get the car in gear, but the car would have no acceleration whatsover.
Old Aug 27, 2009
astigmatik's Avatar
astigmatik is an unknown quantity at this point
any update on this? having the same issue as we speak.
Old Aug 27, 2009
grey2k11's Avatar
It was the clutch. I also replaced the fly wheel while I was in there. If u hav ne questions about the replacement just message me. It was a pain in the ***, but I'm up and running again.
For anyone else reading this, would my gears become rougher after replacing my stock fly wheel with an 8lb aftermarket. And my clutch with a stage 1?
Old Aug 28, 2009
speedfoos's Avatar
Gears won't be rougher, but your engagement won't be as smooth. The lightened flywheel has less rotating mass to absorb the shock of the drivetrain engagement. You probably also notice that you have to rev a little higher now to get a smooth transition from whoa to go.
Old Aug 28, 2009
Awjvail's Avatar
Awjvail is an unknown quantity at this point
My 2002 is doing this when going into reverse sometimes.
Sometimes it takes multiple attempts to get the gear to go in.. dunno if it's a clutch issue or what but it's kind of annoying.
155k miles on original clutch.
Old Aug 29, 2009
EMK20a2's Avatar
EMK20a2 will become famous soon enoughEMK20a2 will become famous soon enough
Any time there is a rough shift in ALL gears or irregular engagement of the clutch it is typically the master cylinder. It could also be the slave, the the master seems to be the weaker point. Check the clutch fluid level and the carpet under the clutch (if the master is leaking there is typically fluid on the carpet).
Old Aug 30, 2009
johnnyboy5000's Avatar
johnnyboy5000 is an unknown quantity at this point
I'm at 165,000 miles on the same clutch. When the car is cold, first and second don't seem to work. I step on the gas and I don't get any acceleration. I've noticed a couple on times that stepping on the gas and the engine doesn't rev, but sometimes it does rev when in first and second. After about a minute, it all goes back to normal and I get full acceleration. The symptom was a dangerous problem for me a few times, when I was going to pull out into traffic, and stepping on the gas wouldn't accelerate me. In a panic, stepping on the clutch, putting the into neutral then back into gear got the car to go. But I could feel the car struggling. I've never added any fuel cleaner to the car and I'm thinking I may have a clogged fuel filter. Does that sound like the case also, besides the clutch?
sesi
Oct 1, 2015 02:03 PM
ThatGuy913
Sep 28, 2015 05:35 PM
speedlever
Sep 24, 2015 07:18 PM
powman02
Sep 15, 2015 07:38 PM
Klame9420
Sep 7, 2015 10:03 PM
