Overheating or loss of coolant, heater blowing cold If you are having overheating of loss of coolant issues, post here!
2004 civic is STILL overheating
Old Feb 14, 2019
smann2's Avatar
smann2 is an unknown quantity at this point
I had a diagnostic done by pepboys, that said my radiator and my Headgasket were both bad. Had both Replaced by my mechanic, which didn’t full fix the issue of overheating. Replaced the thermostat and coolant temp sensor, still overheating. Going to be doing the water pump tomorrow.
Any idea, assuming the water pump also doesn’t fix the issue, what could be wrong? I’m out of ideas and so is my mechanic. I’m already almost 2k deep in repairs and wouldn’t be worth junking at this point as everything already been fixed.
Old Feb 14, 2019
mikey1's Avatar
Re: 2004 civic is STILL overheating
Old Feb 14, 2019
smann2's Avatar
They only charged 45$. I originally wasn’t going to fix it but stupidly got talked into it by my dad.
Old Feb 14, 2019
mikey1's Avatar
yeah but how much did the repairs cost? which got you nowhere?
stop throwing parts at it, and find somebody who can tell you what the real problem is
Old Feb 14, 2019
smann2's Avatar
The mechanic who I had fix it, said both the head gasket and radiator were busted, as well as the thermostat, water pump, and coolant temp sensor.
Old Feb 14, 2019
What does pepboys want your installer to replace next?
Old Feb 14, 2019
Slumpertcivic's Avatar
Lots questions...
Would not surprise me if your mechanic didn’t use OEM head gasket and no mention about sending head to machine shop to verify it’s flat.
If pep boys / your mechanic did not tell you exactly which cyclinder was leaking then they did not correctly diagnose a failed Honda Civic headgasket.
Its been reported some aftermarket waterpumps can fail with the impeller coming off. Sure sign of that would be full coolant system, heater turned to max, engine warmed up and no heat since there is no coolant flow.
What would you like from this forum?
Old Feb 15, 2019
mikey1's Avatar
i have a very hard time believing all of those parts failed at the same time,
also....if the coolant sensor is faulty how do you really know if its over heating? it might be giving false readings
Old Feb 15, 2019
This is not how problems are solved.
Old Feb 28, 2019
smann2's Avatar
I’m a loss
i had my mechanic diagnose and replace my radiator and head gasket. After i was still overheating we replaced the water pump, thermostat, and coolant temp sensor.
Still overheating.
Before he did the radiator I was leaking coolant but when I put coolant in I wasn’t overheating. Now I am. I think it’s that the radiator was done incorrectly, he said that’s not the case, but I don’t know anything about working on cars but that seems logical to me. Any ideas?
Old Feb 28, 2019
GolNat's Avatar
Prelude Owner
Re: I’m a loss
Was a head gasket test performed? Was the system burped properly? Might still have air in the system.
If his original diagnosis didn't fix the issue then he owes you to fix it!!
If he is not capable of fixing it he owes you some sort of refund and take it to someone else.
Old Feb 28, 2019
Re: I’m a loss
Moved to proper section...geez, nobody can read english anymore to find the proper section?
Old Mar 1, 2019
merged thread to original thread.
geez, really a "I will post anywhere"
Tdubs613
Aug 17, 2018 07:25 PM
Tehmke
Jul 16, 2018 09:48 AM
com10goat
Jun 11, 2018 12:22 PM
Mastinarx
May 9, 2018 07:57 AM
mhammond1127
Apr 3, 2018 01:47 AM
