Electronics Post your electronic questions here!
Add a dash light dimmer switch?
Old May 8, 2024
Nessmuck's Avatar
Nessmuck the path ginder
Nessmuck is an unknown quantity at this point
Has anyone added a dimmer switch for the dash lights?
If so, how?
My aftermarket radio has an input for gauge lights, if i supply 12v to it, will it dim the radio?
Any help, ideas, positive input appreciated.
Typical negative input like why, it's stupid, etc, not appreciated.
Old May 8, 2024
Re: Add a dash light dimmer switch?
The dash lights (HVAC controls, OEM radio, dash gauges, etc.) should be controlled by the dimmer switch on the gauge cluster. For aftermarket radios, however, we've historically seen more bad happen (frying instrument clusters is a common one) from hooking up the orange dimmer wire on the radio harness, so we tell people to not hook that wire up.
Old May 8, 2024
Colin42's Avatar
Dash lights are dimmable from the factory.
Don't hook up the aftermarket dimmer wire, some decks you can program the dimmer based on the time.
BCMEDIC
Electrical
Aug 21, 2019 03:33 PM
Scout1
31
Nov 23, 2013 03:23 PM
quattro
Jul 7, 2009 10:42 AM
halpierce
Jul 10, 2005 05:47 PM
Bolemite24
Jan 7, 2004 03:32 PM
