Electronics Post your electronic questions here!
Replaced Gauge Cluster, SRS Light Now On
Old Nov 25, 2023
superchess's Avatar
superchess is an unknown quantity at this point
Hello everyone.
My speedometer on my 2005 sedan EX auto broke 5-7 years ago, and yesterday I went to the junkyard and pulled a speedo from a 2003 sedan LX auto. The car was in a minor frontal collision but the airbags had not deployed (mustve been like a 5-10mph collison). Unfortunately I was stupid and didn't unplug the battery when doing the cluster swap, and now even after putting the original cluster back in the SRS light stays on. I took the car to autozone and they werent able to get an OB2 reading even after waiting 2-3 mins. I tried the ob2 reading with the new-to-me cluster plugged in and no cluster plugged in. I shouldve brought the original cluster to try as well... Did I blow something important??
I was wondering what I should do from here, if I reset the SRS system like ive seen on this forum by shorting those two plugs will that damage the system? And will the code come back if there truly is a problem? I thought maybe the issue is just because the LX didn't have side airbags, but even after putting in the original cluster the SRS light stays on.
Thanks for your time.
Old Nov 26, 2023
Colin42's Avatar
Re: Replaced Gauge Cluster, SRS Light Now On
Could see if the dealer can reset it
Old Nov 26, 2023
superchess's Avatar
Yeah, have an appointment for Dec 14 for a diagnostic. I dont want to mess with the car anymore until then. Praying that its just a fuse somewhere and not an SRS computer or part...
Old Nov 26, 2023
You can read the SRS code at home. Just takes a bit of finagling and paying attention to blinking lights
https://www.civicforums.com/forums/3...ml#post4768801
As far as resetting the SRS code by doing the plug/unplug/key on/off dance, shouldn't hurt anything. If it's a locked in/active code, the SRS light will come right back on
Old Nov 27, 2023
superchess's Avatar
Yeah, I've seen those steps to read the code at home. I think once I get some time I'll disconnect the battery and check some fuses and check that out. I don't think there's much I can do now except for see what the dealership says in Dec. I'll update the thread once they look at it...
Old Dec 15, 2023
superchess's Avatar
UPDATE: I was worried I would mess something up doing this stuff on my own, so I let the dealer handle it. They said that it was just a code because the circuit was interrupted (by me taking out the cluster without disconnecting the battery). A reset fixed the airbag system. PSA: DISCONNECT BATTERY WHEN DOING ELECTRICAL MODIFICATIONS!!
Apollyon02ex
Jan 28, 2012 06:22 PM
stock03
Dec 29, 2009 07:12 PM
joebull1
Apr 15, 2009 05:25 AM
V16Civic
Aug 13, 2006 06:33 PM
chicohonda02
Feb 26, 2005 10:32 PM
