Electronics Post your electronic questions here!
Cluster mileage correction
Old May 14, 2020
rexmax's Avatar
rexmax is an unknown quantity at this point
Have a 02 Civic LX and the cluster was changed. Have the mileage from the original cluster and current replacement.
How can i get the mileage corrected?
Old May 14, 2020
BrotatoChip's Avatar
Super Moderator
Re: Cluster mileage correction
A dealer should be able to program the correct mileage.
Old May 14, 2020
rexmax's Avatar
Thanks Brotatochip, will give them a call.
Old May 29, 2020
rexmax's Avatar
Spoke to Parts Person at Honda and he said that they can not reset mileage on electronic clusters. If it is replaced at the dealer they install a label on the drivers door pillar stating original mileage and replacement cluster mileage. Other than that keep your original cluster and document that mileage along with the mileage on replacement cluster.
Also I am going to check with my local notary and see if they can create a document and notarize it and keep a copy in the glove box.
Old Jun 2, 2020
SKcivic's Avatar
SKcivic is a jewel in the roughSKcivic is a jewel in the roughSKcivic is a jewel in the rough
You should look up taninelectronix on eBay, or try Tanin Auto Electronix in Racine, Wisconsin.
Old Jun 3, 2020
rexmax's Avatar
Thanks, this is what i have been looking for.
Old Jun 3, 2020
Super Moderator
If the cluster mileage is lower than the actual car you can run up the cluster by hooking it up on a bench and supplying a fake vehicle speed signal.
Old Jun 4, 2020
rexmax's Avatar
About 99% certain I can do this, will need info on how to do this if its ok with you.
Thanks again for your help.
Old Jun 4, 2020
Super Moderator
PM'd
Dannyboy1616
Interior
Feb 17, 2020 03:02 PM
FijiEM2
Apr 9, 2018 06:27 PM
jeremyp969
May 26, 2012 03:59 PM
natebe4
Feb 4, 2012 08:12 PM
spunger
Mar 11, 2007 11:55 PM
