Electronics Post your electronic questions here!
dimmer switch bypass
Old Apr 27, 2019
02civilx's Avatar
02civilx is an unknown quantity at this point
so on my 02 civic lx 2 door some yahoo who installed the radio I guess fried the dimmer switch and as of now a new cluster is not in my budget for next few months. is there a way I can connect 2 wires together and bypass the dimmer switch? its not the fuse. I removed the wire he replaced the fuse with and installed the proper fuse. cluster lights, ac control lights no work. all my external lights work though. I just wanna bypass this stupid switch. I keep my dimmer lights on full light anyway
Old Apr 27, 2019
02civilx's Avatar
Re: dimmer switch bypass
update:
I removed the radio and the radio harness is a mess. the red/black wire was all melted to the other wires all the insulation was peeled off its so far gone. im gonna rewire the radio. I only want the cluster lights to work. I don't care 2 cents to have my ac lights work. if I cut the red/black wire at the cluster pigtail and basically attatch a new wire to the cluster side of the red/black wire and ground it out to the body, it will restore back lights to my cluster right?
Old Apr 27, 2019
Slumpertcivic's Avatar
Most likely your cluster circuit board has also burned out a trace or two.
I would highly suggest removing the cluster and inspecting the circuit board.
Old Apr 27, 2019
02civilx's Avatar
My car is standard. I have a automatic cluster will it work?
Old Apr 27, 2019
02civilx's Avatar
Let me rephrase. The automatic cluster is from my old 01 civic I scraped
Old Apr 29, 2019
BrotatoChip's Avatar
Super Moderator
You can use an automatic cluster in a manual but your odometer will no longer be accurate. I don't think there were any wiring changes between '01 and '02 but I cannot say for sure.
Old Apr 30, 2019
mac25's Avatar
Dr Krieger of Modification
Cluster will be fine, I'm running my auto cluster after I swapped to manual.
-remember to do a gauge cluster reset/cluster function check, or the rpm gauge will not work.
There are DIY videos on YouTube
nhartfield
Apr 10, 2018 01:05 PM
clams
Nov 10, 2011 06:56 AM
jcool78
Jul 20, 2010 10:50 PM
EM2_01
May 2, 2009 11:48 PM
superdewey58
Dec 12, 2007 07:40 PM
