Dash Cluster Lights Stop Working
I installed an aftermarket radio a few weeks ago. Everything worked good until the rca cables got snapped in the amp. Everything still worked even after i fixed it. But the next day, the lights on my dash cluster didn't work. The leds in the cluster weren't blown nor was the fuses under the hood .I didn't check the secondary fuse box, though. The gauges still worked, they just didn't light up, as well as the a/c ***** and the taillights. I checked different forums as well as videos, but to no avail. My radio seems to be okay. The orange wire was isolated and well taped up. There was another orange wire that was connected to a blue connector, but that didn't seem like it was a problem. I took out the cluster, and it doesn't have any burn marks or smell burnt. All my lights work except the taillight, a/c *****, and the cluster. I just don't know what to try next.
Re: Dash Cluster Lights Stop Working
try putting the stock stuff back in, see if that makes it work?
you may have fried your cluster, i'm guessing you connected the orange illumination wire?
Yeah i replaced the small lights fuse even though it wasn't blown. it didn't change anything, and i isolated the orange wire, but i'm no where near a mechanic so i don't know what wires illuminate and such .
Disconnect the new radio. There are usually two (orange?) wires labeled illumination + or - on the afternarket and EZ adapter harnesses, make sure BOTH are disconnected from the cars harness.
Time for a good wiring diagram and a voltmeter.
If tail lights don't work, then the front parking lights should not work either....and if those are dead then the dash lights should also be out.
I'd start testing by checking any of the lights that don't work.....is power missing? Is ground missing? That answer determines the next steps.
If power is missing, I'd then move to testing at either the headlight switch or the taillight relay.
The wiring diagram is important here when it comes to figuring out what you test for, because the headlight switch does not control power to the lights...
Why not?
So someone had put a 30 fuse in the acc radio fuse(a 7.5 fuse) under the steering wheel backup fuse box . So I replaced it with a 7.5 and now half of my dash works as well as my tail lights and my a/c *****. What could be the problem from there? I'll upload a picture.
UPDATE:
Erich99
Dec 17, 2017 01:35 AM
sulfonate
Jul 27, 2017 07:38 AM
Klame9420
Sep 18, 2015 12:37 PM
Charger4692
Jul 7, 2009 03:39 AM
