Electronics Post your electronic questions here!
2001 ex sedan cruise control issues.
Old Apr 15, 2019
Sellacell's Avatar
Sellacell is an unknown quantity at this point
When I first got the car (a couple of weeks ago) the cruised worked a couple of times but not consistently. The few times it worked, the light on the dash came on, but the main switch light never did. I pulled main switch and two of the terminals were kind of corroded so I cleaned them with sandpaper and put a little bit of lithium grease on it, still doesn’t work. The dash control looks fine. Checked all of the fuses with a test light and they are fine. It’s an auto and the brake lights work so I don’t think it’s the switch on the brake pedal. SRS light is on. Any suggestions of what to check next?
Old Apr 15, 2019
Colin42's Avatar
Re: 2001 ex sedan cruise control issues.
think there's two switches, the other one is stuffed way up in the dash
Old Apr 15, 2019
Sellacell's Avatar
Would it be connected to the other switch with a wire? How would I chase it down? I had read somewhere that the air bag light that is on could be causing it, but I’m not sure how
Old Apr 16, 2019
Sellacell's Avatar
Update, I cleaned the throttle body last night, and I was checking the tightness of the cable. Everything seemed fine, and I didn’t really do anything to it, but the cruise worked on my commute this morning. We’ll see if it keeps working. Also, it’s running a lot better and at lower RPM after cleaning throttle body. Used to run 4500 @ 80mph and this morning it was running less than 3500
skj88
Electrical
Mar 30, 2025 06:31 PM
Jaren000
Electronics
Nov 13, 2018 01:39 PM
Macleen1229
Jul 4, 2016 09:35 AM
firemanfuq
Apr 13, 2010 06:07 PM
DieMaster
Oct 13, 2006 08:28 PM
