cruise control still not working
Old Oct 10, 2006
DieMaster's Avatar
DieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of light
i tested all the inputs / outputs on the CC unit and it still wont engage. heres what i checked:
clutch switch works
brake switch works
set resume cancel works
power switch works.
CC light in dash works.
all fuses are good.
i took the actuator w/ computer out and everythign looks fine.
what do i do? where can i get a actuator / computer for it less than the dealer?
Old Oct 11, 2006
nj_represent's Avatar
nj_represent is an unknown quantity at this point
Junkyard, does the cruise control light not come on when you press to set it? And it doesnt actually move the cable.
Old Oct 11, 2006
DieMaster's Avatar
no no light, no attemt to keep speed. i'm hoping it's a borken solder joint. like it's not getting power but it is.
Old Oct 12, 2006
is the cruise button on the lower dash pushed in? i had that problem once haha
Old Oct 12, 2006
boosted.es2's Avatar
boosted.es2 is a jewel in the roughboosted.es2 is a jewel in the roughboosted.es2 is a jewel in the rough
i have the same problem. with the cruise control button pushed down the cruise control doesnt work. when i press any of the buttons except cancel on the cruise control the light comes on and says its working but it doesnt hold my speed.
Old Oct 12, 2006
now does it actually do something like try to hold speed, but it just off by 5-10 mph? maybe you need to tighten the cable
Old Oct 12, 2006
shepherd79's Avatar
shepherd79 is an unknown quantity at this point
i had simular problem. It would turn on and run for a little while but after that it would shut off. I had to push dash button on and off and it would work for a while again.
I tracked down AC control box (under the dash, driver side), repalced it and it works like new.
Old Oct 12, 2006
DieMaster's Avatar
mine dosent even try to keep speed. light never turns on.
Old Oct 12, 2006
yeah mine doesnt try to stay with it. the cruise control light comes on and right after i let off the gas its as if cruise control is non existant.
Old Oct 13, 2006
DieMaster's Avatar
u could have a broken cable or it just fell off.
mine still dosent work after i rebult the actuator.
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
cukaracha
May 16, 2015 02:11 PM
ORskier
May 3, 2015 12:54 PM
cooldan1
Apr 23, 2015 10:49 AM
Civic316
Electronics
Dec 10, 2001 12:03 PM
