Honda civic PO135 code 02 sensor
Old Mar 6, 2025
Cbo408's Avatar
Cbo408 is an unknown quantity at this point
Long story short my 05 Honda was totaled. The motor (D17A1 non vtec) was still new as it was freshly redone so I saved it and installed it into a doner car 03 Honda civic EX that had a D17A2 (vtec). I swapped my good engine, harness and ecu. Everything runs great and I have no issues other than this darn PO135 code. I have replaced the 02 sensor with a brand new factory one and still get the code. It pops up within 5 seconds of resetting. Any input would help me out! Thanks
Old Mar 11, 2025
Re: Honda civic PO135 code 02 sensor
which sensor did you get?
for the 03 or 05? Which exhaust are you using?
Did you get Denso or NTK sdensor?
Old Mar 11, 2025
Cbo408's Avatar
since everything is now, 05 I bought the new sensor for an 05. It was factory Honda, which is made by Denso. I also tried my original one from my 05 which I never had any issues on. As far as the exhaust, I am running the 05 manifold and I had to modify the current 03 exhaust to lineup correctly to the 05 manifold as it was a different downpipe. The original cat that the car came with is still within the exhaust system, but it’s towards the center of the car. I left it there and plugged the sensor thread because I didn’t think it would have any effect on the current set up.
Old Mar 11, 2025
?!? so you are running two cats?!?
Old Mar 11, 2025
Cbo408's Avatar
Yes technically. But the second one is in the middle of the exhaust system and I have the two sensors on the original manifold that has the built in cat as it came with the motor that in it. There is no sensor to the rear existing cat. I can cut it out but I didn’t think it would make a difference or hurt anything because it’s after the two sensors I’m using now.
Old Mar 12, 2025
loosen exhaust between both systems and see what happens
Old Mar 12, 2025
leok99's Avatar
leok99 is an unknown quantity at this point
Unplug the sensor, turn car to II and measure the voltage of the two heater wire pin on the plug, is it 12v?
Old Mar 12, 2025
Cbo408's Avatar
no change
fat_eminem
Sep 6, 2024 10:15 AM
hondacivic2006s
Apr 25, 2022 06:18 AM
kikoavy
Jan 14, 2021 04:50 PM
raisinsmommy
Oct 21, 2011 09:34 AM
klewlessnoob
Jul 13, 2010 08:41 AM
