where is the starter in a hatch K-series?
Old Sep 4, 2024
pscarbor's Avatar
pscarbor is an unknown quantity at this point
Cool where is the starter in a hatch K-series?
Originally Posted by mikey1
you need to buy yourself a service manual
Service manual doesn't tell where the starter is located. mine would not crank this morning, been looking for the starter for about an hour now. Near as I can tell it doesn't have one.
Old Sep 4, 2024
BrotatoChip's Avatar
Super Moderator
Re: Where is the starter? (diagram please)
You replied to an eight year old thread with pictures showing you exactly where the starter is located.
Old Sep 4, 2024
pscarbor's Avatar
Pictures show very little about where the starter is located, and the service manual is no help either. Turns out in a Civic Si it's under the intake manifold.
Old Sep 4, 2024
Si in US is the hatch, completely different engine - you got the wrong manual then. This post is about the non-hatch with the D engine, you have a K engine...
Old Sep 5, 2024
Super Moderator
You can get to it from underneath but it's a pain. I usually just remove the intake manifold.
Old Sep 5, 2024
pscarbor's Avatar
I have the correct manual, I have a hatchback. The pictures are not useful; what the OP asked for was a DIAGRAM which nobody provided. I thought I'd update the post for those of us who have a Si and need to replace the starter.
And look at that I didn't provide a diagram either!
Old Sep 5, 2024
pscarbor's Avatar
Thanks for the info, the car has 250k miles on it and so I'll probably have to replace the starter one day. This time it wouldn't turn over; turned out to be the clutch safety wasn't working. Easy solution, I wired it out. Fifteen minutes work, mostly hunting solder. Now I can kneel outside the car, start it in gear, and probably run over myself - but barring something that stupid I don't think I'll miss the clutch safety switch.
I wired out the one on my Dodge 3/4 ton pickup ten years ago and so far I've managed to survive without it.
Old Sep 6, 2024
Colin42's Avatar
Re: where is the starter in a hatch K-series?
The starters last a very long time, leave it alone until it fails. The aftermarket ones arent nearly as good as the factory ones
jimwe
Feb 6, 2013 10:28 PM
GoOkStA
Jun 19, 2003 01:29 PM
sharks1139
May 20, 2003 02:07 PM
ASuave
May 9, 2003 12:55 AM
Kadenx
Apr 24, 2003 10:04 PM
