I need help n a diagnosis??!!
Old May 16, 2024
jcov14's Avatar
jcov14 is an unknown quantity at this point
Unhappy I need help n a diagnosis??!!
So i did a compression test on my 03 civic since its smoking after starting from the intake manifold. Head gasket was supposedly replaced. I changed the thermostat to oem and the coolant fan sensor.
I wanted you guys opinion on what it could be as to why my compression test yielded that cylinders 2&3 were extremely low.
The compression psi test showed
CLY 1 -125-127psi
CLY 2 - 50 psi
CLY 3 - 24-26 psi
CLY 4 - 160 psi
could it be bent valves?
Pistons?
Camshaft ?
Just want to know what to have the shop look for or repair.
Old May 17, 2024
Colin42's Avatar
Re: I need help n a diagnosis??!!
Probably bent valves.
Just let the shop do their thing, they'll figure out what's wrong.
Old May 17, 2024
jcov14's Avatar
Bet I appreciate you
Bulzi73
Mar 1, 2020 08:52 PM
dbhuger
25
Jun 9, 2018 10:59 AM
Nov 22, 2016 07:27 AM
kyle_l88
Jan 12, 2014 12:51 PM
SSMCivicCoupe
Jan 24, 2013 11:08 PM
