SOLVED Unknown Nipple Cover??
Old Sep 14, 2023
dedspec15's Avatar
dedspec15 is an unknown quantity at this point
So i have an 05 Honda Civic Lx 1.7 and i’m having trouble finding out what goes on this top hole. Is it a hose? Cap? It’s on my intake on the right side below the fuel rail. When i put my finger over it, it sucks and my car idles lower.
No clue what the connection right above the hose is.
Old Sep 14, 2023
Colin42's Avatar
Re: Unknown Nipple Cover??
Vacuum connection for cruise maybe? Should just be able to put a standard vacuum cap on it.
Old Sep 15, 2023
BrotatoChip's Avatar
Super Moderator
I think it's just supposed to be capped. A vacuum leak can cause idle issues.
Cruise control is all electronic in 7th gens, no vacuum input.
Old Sep 15, 2023
Colin42's Avatar
my bad, never looked at a 7th gen cruise module. I was thinking of the 6th gen ones
Old Sep 15, 2023
you know, nipple cover made me think on some stuff
Consider solved?
Old Sep 15, 2023
Super Moderator
How dare you not have intricate knowledge of every Civic generation
Old Sep 17, 2023
isn't that the PCV connection on the intake mani?
Old Sep 18, 2023
Super Moderator
The hose on the bottom is. There is a fitting right above the hose too.
Old Sep 18, 2023
yeah, I was referring to the barb above the existing hose. I can't remember wtf that other one was. Definitely too small to be brake booster, and iirc, brake booster comes off the aft side of the IM
edit: did a bit more searching, particularly on ebay, since when they sell intake manifolds they usually have the hoses attached. Every single one I found has that port capped off, regardless if they have the PCV vacuum tube attached or not. I swear, if that's capped off on every D17 intake mani, I'm gonna be pissed at myself. Could have used that for a vacuum manifold instead of cutting the brake booster line.
Old Sep 19, 2023
Super Moderator
Re: SOLVED Unknown Nipple Cover??
I was thinking the molded plastic actually blocked that fitting. Meaning that is wasn't actually a vacuum source. It seems I was wrong.
scarfacew3
Aug 12, 2022 09:42 AM
BigBear8080
Aug 26, 2012 10:07 PM
tagailoilo
Jan 25, 2009 05:46 PM
shmik1
Jul 6, 2006 12:43 PM
nunzio42
Oct 28, 2003 03:15 PM
