what hose is this?
what hose is this?
I just put the intake on and the hose is really close when it goes over and I dont want it to rub or tug at it when it moves. So I ran the hose under the intake instead of over. It appears to work fine, but im curious as to what the hose is for, it's not kinked or even bent its just slightly curved a bit. I just want to make sure I dont have any potential for damaging something.
pics..
TIA!
pics..
TIA!
I can't tell if its the fuel hose or not... if it says "Fuel Hose - Do Not Kink" Right on it, then it is, if not, then its a coolant hose for the heater or a vac hose.
its better where it's at than over the top..
its not kinked or anything and I didnt see fuel written on it.. I think it's all good im just paranoid..
If its resting on the pipe, you're going to want to put some sort of insulation over it. The filter on a stick pipe will get hot enough to melt the hose sleeve. If it is the fuel line, there's a hard line inside of it, but cover it anyways. Exhaust wrap or aluminized heat shield will work.
Hutch1051
Sep 29, 2015 09:20 AM
Sep 27, 2015 11:33 AM
thaler4cuse
Sep 7, 2015 08:25 PM
