Limp mode? Bypass? [solved]
Old Sep 9, 2023
MuddFlapps's Avatar
You gonna eat that?
MuddFlapps is an unknown quantity at this point
After replacing the ECU on my '02 EX, I'm starting to wonder if I did in fact kick my car into limp mode by trying to remove the EEPROM chip.
I'm throwing the p1607 code for ECM internal blah blah blah. If I did cause it to go into limp mode by doing so, wouldn't there in THEORY be a way to prevent the ECM from detecting it as a "problem" and therefore bypassing it?
I can start the car, clear the DTCs with an Innova 3100e scanner, and the car seems to run alright after I do it. The problem is, it comes back every time I restart the car. Does anyone else have any input here?
Old Sep 9, 2023
Colin42's Avatar
re: Limp mode? Bypass? [solved]
Get an non butchered ecu
Old Sep 11, 2023
BrotatoChip's Avatar
Super Moderator
There is troubleshooting in the service manual but you won't like what it says.
-Clear the code
-Turn ignition on
-Wait 40 seconds
-If the code comes back, replace the ECM/PCM.
You probably could trick it into not throwing the code, but you'd have to know what exactly it's looking for and not seeing.
Old Oct 6, 2023
MuddFlapps's Avatar
You gonna eat that?
Re: Limp mode? Bypass?
-Clear the code
-Turn ignition on
-Wait 40 seconds
Okay, so here's an update.
I decided to stop screwing around and just bit the bullet. I went to ebay to see what I could find.
Lo and behold, I found an ECM, Key, and ignition guts........FOR $62 SHIPPED. Most other sellers are asking $200+
I installed everything......worked like a champ! The reason I am coming back to post here is that I wanted to make a note for anyone else who might read this and decide to replace their ECM.
1. A PLM-L56 ECM ***WILL*** WORK IN PLACE OF A PLR-L55 ECM.
2. A NEWER STYLE HONDA TRANSPONDER KEY (e.x. HO03)***CAN*** HAVE THE TRANSPONDER CHIP RETROFITTED INTO AN OLDER STYLE HD106PT KEY BLADE (2002 AND EARLIER). THIS MEANS YOU CAN USE YOUR OLDER LOCK CYLINDER AND KEY
cc2e
Jan 13, 2022 04:06 PM
Herbie1964
15
Jul 2, 2009 04:33 PM
1badgt4
Dec 23, 2005 11:53 AM
andyman97
Engine Swaps
15
Mar 11, 2004 11:48 PM
