Going into limp mode-not sure why
Turbo Guru
Ok, my car does fine under 7 or lower psi. As soon as I switch to high boost (about 10 psi), I get almost to the top of second and it goes into limp/safe mode and I can't get it over 3400 rpm. I'm not sure if it's the clutch that can't handle the torque so it overrevs or I'm not bleeding out enough manifold pressure through my check valve. I'm just using 2 regular gm check valves in between the map and the manifold but I've been thinking of using the missing link for awhile. Any thoughts or suggestions?
Re: Going into limp mode-not sure why
EDIT: It could be that the vacuum pressure is too much for your check valve set up to bleed off and your ECU is seeing positive pressure. I would bet on it being that.
Turbo Guru
Well, I talked to Mike Stafford, his suggestions were: go with autolite plugs and gap b/w 32-35, keep an eye on my a/f gauge to see where my fuel mixture is and to run a test light to make sure the alcohol injection is working. I've swapped the plugs but haven't tried running it again yet. I'll be trying soon though just to see what happens.
Turbo Guru
Originally posted by guns
Hey brother,
PM me with results when you figure it out. I am still having the same problem. I put in the iridium plugs. I tested the fuel and alch. Keep me posted thanks
Hey brother,
What did you come up with after those tests?
I am at a solid 6psi, any more and everything goes to ****.
I am not sure yet. I just know that they are spraying,.
Originally posted by dober
Add another 2 check valves to your string of check valves.
Thanks I added another PVC valve(check valve) on line w/ my MAP sensor. It did the trick up to 10psi on new DH clutch. WIll up it to 12psi when I can take time to tune for safety.
OK anyone having this problem get the Missinglink Check valve.........
I installed mine tonight and it did the trick. Had the boost set too high and spiked at 14psi. The missinglink held and no check engine light. It works perfect. No more MAP sensor problems and reseting the battery.
There is someone on this site selling one. Look under the sales forum.
Originally posted by slowciv
im sorri but what is a check valve? im getting my kit in a few weeks so i geuss i will be getting this prob 2?
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
loosescrew84
16
Aug 11, 2015 07:08 PM
liagreenhalgh92
Jul 21, 2015 01:31 PM
Khmi
Jun 23, 2015 11:03 PM
