2001 Honda Civic EX fuel leak
Old Jul 15, 2023
argint's Avatar
argint is an unknown quantity at this point
2001 Honda civic EX, I was changing my axel today and when I lifted the front end up I noticed a puddle of fuel from the rear. I traced it back to what seems to be the filler neck hose that's attached to the tank. My question is where is this leaking from exactly is it the tank grommet/seal or the hose that's attached to the tank from the filler neck? I've attached some photos I hope I can get some answers. I was trying to find that rubber seal for sale but couldn't find anything, not sure if that's just part of the tank and if it's replaceable.
Old Jul 15, 2023
Svtguy415's Avatar
Svtguy415 is an unknown quantity at this point
Re: 2001 Honda Civic EX fuel leak
I would look into that hose also, looks swollen (maybe the issue?). That worm clamp looks overtightened. As far as the leak i dont see any immidiate source judging by the pics, have you checked with the car on for possible location of the leak?
Old Jul 15, 2023
argint's Avatar
No I haven't turned the car on since I noticed the leak, once I finish the axle and and some other things I'll give it a start and see if I can't visible see the leak. I was smelling gas fumes for a while but I wouldn't see any puddles anywhere so I figured it was some evap leak somewhere.
It seem to just be coming from either the hose there or the tank? No where else do I see fuel.
would this be the hose that looks to be leaking?
art?
Old Jul 15, 2023
Svtguy415's Avatar
Unfortunately (my opinion), the gas tank is plastic, so someone may have overtightened that hose and broke part of the tank at the seams where the male and female end meet, i hope iam wrong but you may need a new fuel tank to solve your issue. If it was me i would disconnect the hose from the tank and further inspect the area as this can be the problem to your leak. This situation sucks, Good luck to you.
Old Jul 15, 2023
argint's Avatar
Thank you for the information, I'll be working on it today and I'll check the hose and the tank and let you know what I find.
Redtail
Nov 13, 2018 02:23 PM
stl01civic
Aug 21, 2015 05:33 PM
superstanko
Apr 28, 2015 04:38 AM
mpadillaaz
Feb 19, 2014 01:27 PM
Lightman
Nov 10, 2001 06:44 PM
