2001 Civic emissions problems.
Old Dec 3, 2022
JulianLewis75's Avatar
JulianLewis75 is an unknown quantity at this point
So, I previously purchased a 2001 Honda civic with a JDM D17A. The car had an immobilizer issue so I purchased and ECU that came from a Vtec civic with the matching key cylinder to get it running. I live in California so I have to pass an emissions scan to get the car registered, but the car with the vtec solenoid connected throws a code for no EGR valve. I'm wondering can I purchase a non-vtec ecu and use a VAFC to control the vtec solenoid so I can pass my emissions test? Thanks in advance.
Old Dec 3, 2022
FRSam's Avatar
Click Here
Re: 2001 Civic emissions problems.
A non-VTEC ECU will simply disengage the VTEC. A CEL will appear but it should have no effect on emissions. Is a CEL an auto fail in California?
Old Dec 3, 2022
Yes pretty much, and what CEL would come on? As long as I disconnect the vtec from the ECU then it should be okay? I just don't want to spend another 100$ to be having the same issue.
Thanks.
Old Dec 3, 2022
FRSam's Avatar
Click Here
Sorry, I messed up, using a non-vtec ECU should yield no check engine lights, but the EGR fault may persist. I'd look at getting that addressed however possible. I don't believe there's any correlation between the EGR and a vtec/non-vtec car. Admittedly, it seems they threw EGR's in whatever cars they wanted - I don't think there's even an explanation for that.
Old Dec 3, 2022
Is there a way to discern a non-egr ecu from an egr ecu?
Old Dec 3, 2022
FRSam's Avatar
Click Here
That, I’m not sure about.
Old Dec 3, 2022
Colin42's Avatar
03+ had egr
Old Dec 5, 2022
BrotatoChip's Avatar
Super Moderator
My '02 also had EGR. I don't think we've ever been able to tell for sure.
rayyan
SOHC D17Ax non-VTEC - VTEC Engine Swaps
Oct 12, 2021 03:37 PM
Artemas Rex
Jun 7, 2021 02:51 PM
JulianLewis75
Oct 6, 2020 06:34 PM
Linkage
Transmission swap
Apr 5, 2019 10:44 AM
cmilien
Jul 30, 2009 03:23 PM
