Squeak became a knocking
Old Nov 29, 2022
2004civicgal's Avatar
2004civicgal is an unknown quantity at this point
Hi all,
I have a 2004 Honda Civic that I replaced the alternator on this summer. Shortly after I got a squealing, you can read about it here. It seemed that a belt was too loose from the repair.
https://www.civicforums.com/forums/3...ml#post4803188
After tightening the belt a bit, the squeak is gone but now I get a terrible knocking in that area. At that point I gave up in frustration and abandoned the repairs and some weeds grew up the sides of the car. But ultimately I need to do something with the car, either fix it or salvage it.
So now I am revisiting it, is it safe to assume the belt is too tight now? Is it possible the new alternator I bought is failing and how would I test that?
Thank you for any suggestions, and all your help in the past.
Old Nov 29, 2022
Colin42's Avatar
Re: Squeak became a knocking
Tale the belt off, give the pulleys a spin to check if any seem weird, and then start the car, see if the noise is still there. Don't run it without a belt for more than a couple mins.
robinc88
Mar 7, 2017 01:26 PM
civicowner123
Oct 9, 2014 11:35 AM
NCCivicNoob
Mar 18, 2012 10:08 PM
bporter1972
May 8, 2009 09:31 PM
2001civ
Nov 30, 2002 11:26 AM
