05 Civic Shut off while driving and will not start back up
Old Nov 29, 2022
Dawson_pitcock's Avatar
Dawson_pitcock is an unknown quantity at this point
Needing some help. I have an 05 Honda Civic that shut off while driving and now will crank but not start. I am getting quite a few codes...
P0339 (Crankshaft Position Sensor A Circuit Intermittent)
P0117 (Engine Coolant Temperature Sensor 1 Circuit Low)
P0344 (Camshaft Position Sensor A Circuit Intermittent Bank 1 or Single Sensor)
P0452 (Evaporative Emission System Pressure Sensor/Switch Low)
P0453 (Evaporative Emission System Pressure Sensor/Switch High)
I did pull the upper timing cover and the belt is still intact, not really sure where to start with all of these codes. Any help would be greatly appreciated!
Old Nov 29, 2022
Colin42's Avatar
Re: 05 Civic Shut off while driving and will not start back up
How did it shut off? Verified timing? Checked fuses? Checked for chewed up wires?
Old Nov 29, 2022
It became pretty much unresponsive to the throttle pedal, wouldn’t accelerate and then just shut off. I have not done any of that yet. I was kind of wondering if wiring would be an issue as well. Seems odd to have all of those codes pop up at the same time.
Old Nov 30, 2022
BrotatoChip's Avatar
Super Moderator
Timing is probably where I'd start.
Chad1971
Oct 19, 2025 10:23 PM
kevin2001
May 22, 2021 03:49 PM
Omer Shahzad
Engine start problems
Jan 1, 2020 11:59 PM
IROKGEN7
38
Feb 18, 2016 07:27 PM
xRiCeBoYx
71
Apr 9, 2011 01:40 PM
