Cylinder head noise
Old Aug 10, 2022
Alexnik21's Avatar
Alexnik21 is an unknown quantity at this point
Cylinder head noise
So I had a question if anyone had this happen.
I re installed my cat back after having a straight pipe on my 01 LX and my cylinder head started making a horrible loud rattle from about 1500 rpm to 2500 rpm. Its runs and drives fine no loss of power but its super loud and it's getting worse over time. Can anyone help?
Old Aug 11, 2022
BrotatoChip's Avatar
Super Moderator
Re: Cylinder head noise
Check your work, something might be loose.
Old Aug 12, 2022
Alexnik21's Avatar
I did I even made sure my bolts are tight and looked around a bunch and wiggled and tapped things with a hammer to listen for that sound and when I rev up by the throttle body I can hear it coming from under the valve cover in the cylinder head itself
Old Aug 12, 2022
afraid you will need to open valve cover to see
or you have a big crack on your exhaust header
Old Aug 12, 2022
Alexnik21's Avatar
No it's not a exhaust leak I'm 100 percent sure it's a head noise
Hayden_Fourroux
Nov 26, 2016 11:06 PM
gmcuajo
Mar 22, 2006 05:33 PM
Kevdroz
Jul 23, 2003 02:30 PM
tronics
Mar 28, 2003 03:00 PM
greg2k1
Mar 23, 2002 04:55 AM
