Help finding & replace parts
Old Jul 30, 2022
Trixxx's Avatar
Trixxx
Trixxx is an unknown quantity at this point
I need help to fix my engine, there are things wrong and I don’t know much, this wire clip is melted off so I know I need to replace this. I recently put new radiator,different battery, coil pack (1), and it seems to me that who had this before has not replaced all the brackets and bolts cause some are missing
Not my engine, just clear photo showing the item I believe I need new and so what does it do and how do I fix
Old Jul 30, 2022
Re: Help finding & replace parts
several parts in there...
can you post a pic of your engine for reference?
moved thread to mechanical issues/engine
Old Jul 31, 2022
Trixxx's Avatar
Trixxx
I think it could be the ECT sensor
Old Aug 1, 2022
BrotatoChip's Avatar
Super Moderator
Yes, that is a coolant temperature sensor. In order for that to melt it would have to get way hot. Is the engine overheating?
Old Aug 1, 2022
Trixxx's Avatar
Trixxx
yes overheating is a problem, just put new radiator in.
Old Aug 1, 2022
Super Moderator
Are you aware that failed head gaskets are very common on these engines?
If that is the melted connector, it appears to still be in decent shape to me.
Old Aug 1, 2022
Trixxx's Avatar
Trixxx
no I am not aware. I was sold this car believeing I would be able to drive it and easy up keep. Now I have a car I can’t drive and more problems than I can understand
Old Aug 2, 2022
Super Moderator
Unfortunately, that happens often. If the coolant system is properly filled, the overheating may not show up during a test drive. See the below thread for more info. You can easily test the head gasket using instructions in the post. Don't waste any more money throwing other parts at it until you get this test done.
https://www.civicforums.com/forums/3...reference.html
Old Aug 2, 2022
Trixxx's Avatar
Trixxx
ok I’m going to get on that right now, this car was supposed to be the thing that turned my life back towards positive…. I been trying to just get a car and drive back to Florida and be with my daughter again
Old Aug 2, 2022
Super Moderator
These can still be very liable if taken care of. The head gasket in my car went around 170k miles. I then took it to 250k before swapping in a bigger engine. I still drive it today with 322k miles.
If you're experienced enough, you can DIY the head gasket too for around $300. It is by no means an easy job though, and it has to be done carefully or the issue will come back quickly.
Old Aug 2, 2022
Trixxx's Avatar
Trixxx
I am not experienced, honestly just trying to wrap my head around this test thing in the link
Brrrt
Feb 1, 2022 02:32 PM
2k2civicsedan
Nov 29, 2007 09:53 AM
HondaNation
Nov 6, 2003 11:14 AM
ZSKCivic01
May 30, 2003 08:41 PM
YanYan
May 22, 2002 12:23 AM
