Valve lapping [solved]
Old Jun 12, 2022
crajnai's Avatar
7th Gen Victim
crajnai has a spectacular aura aboutcrajnai has a spectacular aura about
Posting here for clarity.
This kind of an order of operation question.
After the head is off does it make sense to go in this order?:
1. Overnight leak test
2. combustion dome surface cleaning
3. replace valve seals
4. valve lapping/seating
5 goto machine shop for resurface and hot tank
5a. Prepare block mating surface
6. Attach intake and new mani gasket
7. install head and cam
8 set valves lash
9. etc
Will the hot tank wreck my work on the valve seats and seals?
Old Jun 13, 2022
BrotatoChip's Avatar
Super Moderator
re: Valve lapping [solved]
Probably a question you should ask the machine shop.
Old Jun 13, 2022
crajnai's Avatar
7th Gen Victim
or should I have them clean it and then do the valve seals and lapping?
Old Jun 13, 2022
Colin42's Avatar
Old Jun 15, 2022
crajnai's Avatar
7th Gen Victim
For future wrenches…
The machine shop said for a low-buck guy like me to strip the head of everything including springs, valves and seals. Give it to them to inspect and machine and clean, then reassemble and lap and lash.
makes sense to me. I just hope I don’t have to do the rings.
Old Jun 15, 2022
Colin42's Avatar
Wont be hard if you have to do them, head is already off, just pull the oil pan and girdle.
Old Jun 15, 2022
crajnai's Avatar
7th Gen Victim
So you replace the pushrod journals/bearings as a rule or not unless they are shot?
Old Jun 15, 2022
Colin42's Avatar
If you don't see any obvious signs of wear I'd leave them.Can't remember, did you say if it was burning oil?
Old Jun 15, 2022
crajnai's Avatar
7th Gen Victim
nope not burning oil…not obviously at least. Will see what the cylinders look like but I’m figuring on doing the rings anyway. I want another 100k out of this engine
Old Sep 18, 2022
crajnai's Avatar
7th Gen Victim
The way this worked out. I stripped the head down and kept it organized 1-8. Machine shop did a great job resurfacing and replace one helicoil for me. My daughter and I cleaned everything, put in the new stem seals, lapped each valve, and put the cam and rockets back on. We set the lash and put the intake on with the new gasket. Dropped it on the block and went from there.
Other than the valves themselves nothing looked terribly worn to the point of failure so we let it be where it made sense. I think it was a good call.
crajnai
Sep 22, 2023 03:00 PM
wolfebrian13
Engine DIY
Apr 12, 2018 12:04 PM
maverickfhs
Jan 1, 2017 12:21 AM
Dornblaser1
Nov 12, 2011 05:44 AM
TRIZ
Engine DIY
61
Oct 30, 2008 04:36 PM
