Header & Cat Delete P420-P1420
Old Oct 30, 2021
jaybird204's Avatar
jaybird204 is an unknown quantity at this point
Hello all i got my first honda civic recently. Always been a Chevy guy. I have had to do a lot of work to make it pizza delivery reliable. Its a 2002 civic HX model. Had an exhaust and headers on it when i purchased it and the upstream sensor was bad so i replaced that after doing the head gasket to make sure it wouldn't just mess up again as i had exhaust gas going into the radiator. Then i got the p420 code so i got one plug de fouler after finding that fix and the p420 code came up again also i notice a sputter before it throws the code. so I ordered a 90degree de fouler. I used that and the straight i drilled out then tried again. Still get a sputter and cel came back on and this time its a p1420. So I unplugged the downstream sensor as the car seems to run best that way but I have to look at that damn cel still. I would just remove the cel bulb at this point but guess that part of the cluster is led and cant. Any suggestions on how to sort this out would be great.
Old Oct 30, 2021
Re: Header & Cat Delete P420-P1420
Which O2 sensor are you putting the non-fouler on? If you put it on (what would be) the upstream sensor, it's not gonna clear that P0420 code and it'll mess with your AFR and thus, engine health. The downstream sensor is the one that looks for catalyst function and efficiency, and that's the one you're supposed to do the non-fouler trick on
as far as the P1420 code, I got nothing
edit: found this about P1420 troubleshooting over on honda-tech
If P1420 was the only code, do the following.
  1. Reset the ECU. (remove fuse #6 (15 amp) from the under hood fuse box. Wait a minute before reinstalling it)
  2. Start the engine. With the car in Park or Neutral, raise and hold the RPM at 3,000 until the radiator fan comes on.
  3. Raise the RPM to 4,000 for about ten minutes.
  4. Test-drive under these conditions:
    1. Maintain a speed of 55 - 65 MPH with the CVT in D position (M/T in 4th or 5th gear) until the readiness code or Temporary DTC P1420 is set.
  5. Check for a Temporary DTC by scanning the car again.
    1. Is Temporary DTC P1420 indicated?
      1. Yes - Check the NOx adsorptive three-way catalytic converter. If necessary, replace it.
      2. No - Intermittent failure, system is okay at this time.
Also this PDF: https://www.autocodes.com/uploads/honda/07-036.pdf. Sure, it has to do with the HCH and Insight, but many steps should be applicable
Old Oct 30, 2021
potentially the cat is reeeealy in bad condition and you really need to replace it. They can plug - try to crap with your a$$ plugged to see how you feel - that's how the engine feels
Old Oct 30, 2021
Cat delete @sdaidoji . HX uses the -A1 exhaust mani. OP got the car with an exhaust and header installed by previous owner
Old Oct 31, 2021
jaybird204's Avatar
It was the downstream after where a cat would be that i used the de foulers. Like i said what is odd is that when that sensor is connected i also get a sputter before the light gets triggered. if i have it unplugged car runs smooth as can be never sputters just runs perfect.but just have to look at that damn cel
Old Oct 31, 2021
woups, looks like i can't read... sorry
Old Oct 31, 2021
jaybird204's Avatar
Yea. No worries. Well anyway from my past experience the downstream would only be there to warn if you have a bad cat condition and not effect car driving conditions. But i seem to be getting some mixed info reading here and there that on the hx model this sensor also communicates to the pcm to keep the lean rich condition right almost like the upstream sensor does. The fact i get strange sputters at cruising speed when its connected seems to prove this to me aswell. So if i had a P420 cause sensor 2 was detecting a rich condition then when i do the de fouler trick and then i get a P1420 could this just mean now im to far out of the stream and not detecting enough NOx? So if sensor 2 detects a lean condition it will cause it to run richer and if sensor 2 is detecting a rich condition the p420 it will make car run leaner. The hx model is a Lean burn it was called by the way.
swillis721
Jun 16, 2021 09:25 PM
redraif
Nov 2, 2017 10:44 AM
glamabilly
Sep 20, 2017 10:01 PM
greeni70
19
Mar 17, 2013 01:14 AM
diskreet
Jan 8, 2007 10:02 PM
