Having a weird idle issue, just swapped heads.
Old Oct 29, 2021
Rizien's Avatar
Rizien is an unknown quantity at this point
Ok, off the rip when I did this it was necessary swap due to lack of options and funds. 05 civic ex, comes stock with D17A2. Head gasket blew, bought a jdm D17A. Put it in, swapped a couple part on the heads and it ran like a screaming banshee. Timing belt broke. Took out the lower cover, crank sensor, ripped the tension straight through the eye on the tensioner. Went to the A2, pulled all the parts that got broke. Pulled the head, put a straight edge on the bottom of the head and it actually looked great. Changed all the broken parts, put the A2 head on the A, set timing and assembled, including changing the swapped head parts back to the A2 head. And she crunk up on the first lick. On to the problem, I've been driving her for 2 weeks now and this is what I've got. When you fire up the car it revs between 1400 and 2400, after it warms up it settles at 1600, with a cammed like idle. When I do it like this low rpm cruising us a pain but I have full tach range, and I'm suspecting the vtec isn't kicking in. If I do not wait for it to level out the car still drives, but I cannot take the tach past 3400, limp mode is what I think it's called. It doesn't actually matter if the car is warm or cold, I can drive it for 39 minutes straight, if I turn it off and back on I have to wait till it settles, which takes around 45 seconds if it is warm. I've got no idea what's going on, changed the IACV and the vtec solenoid. I'm at a loss, starting to think I need buy one of those tuning mods, get it hooked up and see if it has a D17 frankintune for vtec. I'm at a complete loss and cannot find any info on this.
Old Oct 29, 2021
FRSam's Avatar
Click Here
Re: Having a weird idle issue, just swapped heads.
If it’s in limp mode, it will throw a code.
Old Oct 29, 2021
Rizien's Avatar
No computer to check for a code, and it tachs fine when I let it warm
Old Oct 30, 2021
what do you mean no computer? these engines need an ECU to run
what do you mean by tach? idle?
Old Oct 30, 2021
FRSam's Avatar
Click Here
I think he means scan tool. AutoZone checks codes for free.
A visual inspection will also tell you if you have codes. Is your check engine light on?
Old Oct 31, 2021
Rizien's Avatar
no scan tool, check engine and maintenance required has been on since I've owned the car. I'm really just looking for someone else who has done this, or maybe thought about doing it. Can't find anyone who has.
Old Oct 31, 2021
Rizien's Avatar
Tachometer guy, engine revelutions, the current power out put of the engine.
Old Nov 1, 2021
Colin42's Avatar
Can't help you if you don't post the codes
RoverJes
Jul 13, 2020 10:05 PM
tadr88
Jun 8, 2015 12:28 AM
jdm_es2chick
Jan 13, 2010 12:30 PM
Rufus
Nov 23, 2006 11:23 AM
Rufus
Arizona
Dec 20, 2004 03:06 PM
