Cam Bore Oring
Old May 5, 2021
vboss5764's Avatar
vboss5764 is an unknown quantity at this point
Cam Bore Oring
I have found the 27x32x2.5 orig from Ebay to be the exact replacement for the cam bore plug, 7th and I believe 8th gen civics. https://www.ebay.com/itm/293918326749 Has anyone found a better tighter fitting oring? I found some X style orings on my Isuzu because the original orings never did the job. seems the size borderlines on being too small
So after some more research, I found a 27x32.4x2.7 oring, little bit beefier like I want, lo and behold I googled it and Honda part # 91318-500-000 came up. This must be the correct replacement. The gasket sets and plugs come with the 27x32x2.5 it seems because the Honda size is NA in any aftermarket I've searched, and Honda parts has discontinued the part number. Every Civic get is drenched in motor oil because of this stupid oring.
thefivespeeder
Feb 23, 2009 05:56 PM
smokedcivic
Nov 3, 2004 10:51 PM
civicRS
May 2, 2003 03:02 PM
MagicRacing18
Dec 11, 2002 05:41 PM
ShadyMilkMan
Jul 17, 2002 12:22 PM
